Old 10-23-2006, 08:03 PM   #4
ukchris
Originally Posted by RandallNeighbour
Hey Jeff, for the life of me I can't make out how he wired up everything, even with the detailed wording and the pix. I sure wish I had a diagram for the dash switch hack (vs. the 4-stalk installment).
Do you mean a regular dash switch? It operates as two momentary switches with a common ground. As you look at the back you attach the ground to the middle pin and a control wire to each of the pins either side of it. If you want lighting run the outer pins to another switch. Same with a second switch if you want all four functions...
Regular spade connectors fit the back of the switch pretty well.
Hope this helps and I haven't lost the plot on the thread!
Chris.
http://www.lawlai.com/sig.jpg
ukchris is offline   Reply With Quote
