Old 08-13-2020, 03:10 PM   #26
Homeoboxter
Originally Posted by sfkjeld View Post
Thanks. I asked the shop whether the solenoid was bad. They concluded it must have been because it was not moving the actuator at all when they first tested it. After replacing, it does move but not to spec. They referred to it as “slow”.
Hence they want to do this engine flush in the hopes of clearing an oil gallery to increase oil pressure in the actuator. Again, that sounds like a Hail Mary. But after your syringe experience, maybe the flush might clear out something.
Must say, I am stunned at how little difference the vario cam seems to make. If as they said, it wasn’t working at all on bank 1-3 when I brought it in, and it’s not working well now, why does the car run so well? I can’t tell the difference. Seems like a lot tech for not much performance.
Well, the solenoid just operates a valve that controls oil flow within the actuator. It still can be totally fine if the actuator is bad, or the oil passages are blocked. It’s not too parsimonious to replace a $500 part without making sure it’s faulty. If you have the solenoid you can easily test it with a battery.
