Old 08-12-2020, 10:05 AM   #11
2ata
Originally Posted by morgal48 View Post
If I understand your issue, have you jacked the wheel carrier up, or let it down, at the LCA ball joint to change the angle? It could be bound up (binded?) due to the non alignment of the holes at the other end where the offending bolt is. The bolt could spin, but not release.
Yes I have tried jacking it up, down, every which way without any advantage.
2ata is offline   Reply With Quote
