Old 08-12-2020, 09:22 AM   #15
dav9515
i am going to put the car up on jackstands to do the sway bar swap and check everything there. i had the noise before i changed the end links and thought those were the issue, turns out it wasnt. I rechecked all the bolts after the noise continued so i am mostly confident they are tight. will give everything a good shaking to see if i can see what may be loose/noisy. I hate just throwing parts at it but its a 97 on original struts and suspension parts so it could be anything really. car only has 53k miles but age is just as detrimental on rubber as mileage.
Originally Posted by Racer Boy View Post
I just recently had the same symptoms on my car. Since I rebuilt the suspension just a few thousand years ago, I was concerned about some component failing so soon. It turned out to be the a loose nut on the driver's front sway bar links, where the bolt goes through the wheel bearing carrier. I cranked the nut down, and the noise is gone.
Guess the mechanic that did the work was an idiot. Oh wait, that would be me...
dav9515 is offline   Reply With Quote
