Old 08-11-2020, 04:55 PM   #11
ECUrepairImad
Immobilizer repair
Although this post is 8 years old the issue with the Porsche Boxster, 993 and 996 all have some drain port issue. The biggest problem is knowing it's going to happen and not being able to do anything about it. A wet immobilizer from this design issue can stop your Porsche in its tracks, convertible keeps going up and down, windows moving on their own, the alarm never stops blaring!!! If you've experienced this issue or own a Porsche 986,993 or 996, you should call Specialized ECU Repair. The Stealership will suck you dry just for diagnostics and sell you a new ECU set or immobilizer for thousands if not hundreds after all labor and programming. Don't forget about towing your inoperable Porsche to the dealership. Buy their waterproof case now if your immo is dry. That way there is no chance of your cars expensive electronics going to waste. Ecudoctors.com For $1495 you get your set repaired, keys rescued, waterproof case, a 5 year warranty and a valet key with 2nd day shipping included. $150 for the case by itself. Don't DIY drain holes in your floor, it's only a temporary measure. A rusty floorboard with holes in it ain't good for value. Don't get screwed. Enjoy your Porsche worry free and get a performance tune while your at it!!! No parts necessary. Get your DME flashed and get smoother starts, more horsepower and more torque. Better gas mileage and faster throttle response. Message me if you need help with your immobilizer. This issue is terrible for such an amazing car to have this "quirk".
ECUrepairImad is offline   Reply With Quote
