Old 08-11-2020, 01:16 PM   #24
maytag
Who's askin'?
maytag's Avatar
Originally Posted by MaxD View Post
For what it is worth I run XP9, have an LN deep sump and the oil pressure does vary widely. Pretty much the same as when I ran an X51 only.
Your gauge sampling rate will effect what dips you see. AIM will use 5-10hz for a pressure sensor, don't know about a VDO gauge.
If you do install a deep sump on a car that is run on the street, install some sort of sump guard. You won't regret it.
XP9 vs DT40.
Somebody? How does the nomenclature for Driven oils work?
