Old 08-11-2020, 02:16 PM   #22
maytag
Who's askin'?
maytag's Avatar
Originally Posted by MaxD View Post
For what it is worth I run XP9, have an LN deep sump and the oil pressure does vary widely. Pretty much the same as when I ran an X51 only.
Your gauge sampling rate will effect what dips you see. AIM will use 5-10hz for a pressure sensor, don't know about a VDO gauge.
If you do install a deep sump on a car that is run on the street, install some sort of sump guard. You won't regret it.
XP9 vs DT40.
Somebody? How does the nomenclature for Driven oils work?
maytag is online now   Reply With Quote
