For what it is worth I run XP9, have an LN deep sump and the oil pressure does vary widely. Pretty much the same as when I ran an X51 only.
Your gauge sampling rate will effect what dips you see. AIM will use 5-10hz for a pressure sensor, don't know about a VDO gauge.
If you do install a deep sump on a car that is run on the street, install some sort of sump guard. You won't regret it.
PCA Intermountain Region Track Chair
SPB #50
