Old 08-08-2020, 05:40 PM   #16
timqqt
Tim, You might have other vacuum leaks besides the AOS. If your mechanic did a smoke test he might have found a cracked hose(s). BUT, if you have major suction at the oil fill tube the AOS is bad.
Yeah. I did see a lot of signs of AOS failure. Like, the car runs rough at idle only when it starts from cold.
I am just curious that does the fault code relates to the failed AOS or the leaking hose.
timqqt is offline   Reply With Quote
