Old 08-05-2020, 02:33 PM   #14
sfkjeld
sfkjeld's Avatar
I think when you get this code, that can also be because the two actuators are not running syncronously, one is working while the other is not, which will result in a difference in timing between the two intake camshafts, but only in a specific rpm range. This does not mean that your engine won`t run. It will, just not ideally. Correct me if I`m wrong. This "fried computer" thing sounds puzzling. It`s hard to imagine that the actuator and the computer both die at the same time... Did they show you the faulty actuator?
The shop claims that when an actuator fails, it often “fries” the Computer. But as I say, this car runs perfectly. Low rpm and high rpm. They are installing a used computer today and presumably the car will then stop throwing the 1341 CEL. I will be surprised if that works. I have asked for all the replaced parts so will receive the Old bank 1-3 actuator and the “fried” computer.
sfkjeld is offline   Reply With Quote
