Old 08-05-2020, 08:57 AM   #1
maytag
Who's askin'?
maytag's Avatar
Originally Posted by WillH View Post
Any preference? RSR look to be the same as Tarret. Godspeed look to be the same as Megan racing.
Looking to get a better alignment to reduce tire wear on daily driver/canyon carver, and maybe go lower than the M030.
oh, and allow me to save you the grief I experienced; when you remove the OEM joints from the upright, use a Pickle fork. There are steel inserts pressed into the aluminum upright, which are prone to coming-out with the oem link because they're seized together from 20 yrs of stick. IF you have a ball-joint separator that will get a claw in under that insert, then you're good-to-go. I couldn't get my separator in there so I used a hammer....... :troll: don't be me; don't use a hammer.
