Old 08-04-2020, 09:33 PM   #13
Homeoboxter
Originally Posted by sfkjeld View Post
No mention of cams being out of time. Wouldn’t the car run differently if they were? And yes, I don’t get how a fried computer would allow the car to run completely normally. Much less still able to throw the same 1341 code with the CEL.
I think when you get this code, that can also be because the two actuators are not running syncronously, one is working while the other is not, which will result in a difference in timing between the two intake camshafts, but only in a specific rpm range. This does not mean that your engine won`t run. It will, just not ideally. Correct me if I`m wrong. This "fried computer" thing sounds puzzling. It`s hard to imagine that the actuator and the computer both die at the same time... Did they show you the faulty actuator?
