				Front Luggage Compartment Light Inop
			Do you any of you lads know which fuse might be related to the front luggage compartment light?  Mine doesn't work, and the bulb itself is not at fault.A check of the fuse index sheet inside the fuse block panel has proven to be of no help, as neither luggage compartment light seems to be mentioned.  Are they perhaps not fused?
 Thank you,
 Ronzi
 '99 Boxster
 Speed Yellow/Black
