Old 08-02-2020, 02:48 PM   #88
Frodo
With fasteners, they are visually different, so it is obvious. As for the drain plugs, LN’s are not marked, while others are, so again it is obvious to an experienced tech.
In my shop, if you are not using an appropriate torque wrench, you won’t be working here very long. Every fastener and drain plug is torqued to specs, period.
Well okay then. I may re-think my approach on these..
On the drain plugs...do you have a different set of torque values depending on new crush washer vs old crush washer?
NO NEED TO RESPOND ON THAT ONE!
