Originally Posted by njbray
Thanks for all the replies.
So I tested my torque wrench and it is between 19.2 NM and 20.1 NM when set at 19 NM. Not sure if this would damage the plug.
I have read on some other forums that the aluminum washer that comes with them may be too hard and it's better to use a genuine Porsche washer!
Anyway..it's still dripping so I guess I have to swap it out and use a new washer or a new plug!
Originally Posted by 1PorscheBoxster986
It is 50Nm (37 ft-lb) for the factory plug. For the magnetic plug it is 19 ft-lb and 26Nm rounded up NJBray. You either mistyped or we just found where your mistake is.
I don't think these posts should get lost in the fray. After re-reading this thread I change my recommendation. Their plug may not be broken like mine was. Unless the OP is 100% sure they got it right the first time, maybe they can go back underneath and confirm the proper torque value and units were used. Let us know how it goes.
