Old 08-02-2020, 08:05 AM   #10
ZDCATC
Originally Posted by njbray View Post
Thanks for all the replies.
So I tested my torque wrench and it is between 19.2 NM and 20.1 NM when set at 19 NM. Not sure if this would damage the plug.
I have read on some other forums that the aluminum washer that comes with them may be too hard and it's better to use a genuine Porsche washer!
Anyway..it's still dripping so I guess I have to swap it out and use a new washer or a new plug!
Originally Posted by 1PorscheBoxster986 View Post
It is 50Nm (37 ft-lb) for the factory plug. For the magnetic plug it is 19 ft-lb and 26Nm rounded up NJBray. You either mistyped or we just found where your mistake is.
I don't think these posts should get lost in the fray. After re-reading this thread I change my recommendation. Their plug may not be broken like mine was. Unless the OP is 100% sure they got it right the first time, maybe they can go back underneath and confirm the proper torque value and units were used. Let us know how it goes.
ZDCATC is offline   Reply With Quote
