So somebody double check me on this. I believe the torque spec is in ftlb not nm? And 19 nm would only be +/-14 ftlbs? It isn't tight enough by +/- 5 lbs? Thus causing the leak?
Originally Posted by njbray
Thanks for all the replies.
So I tested my torque wrench and it is between 19.2 NM and 20.1 NM when set at 19 NM. Not sure if this would damage the plug.
I have read on some other forums that the aluminum washer that comes with them may be too hard and it's better to use a genuine Porsche washer!
Anyway..it's still dripping so I guess I have to swap it out and use a new washer or a new plug!
