Old 07-31-2020, 10:16 AM   #226
1thenaton1
Originally Posted by truegearhead View Post
There seems to be endless Audi 4.2l options. Is there a year/model you want to stick too? .... Has anyone attempted to proceduralize the 4.2 swap, even from a high level?
You are best off looking at the C5 A6 and S6 variants of the 4.2. S6 has forged rods i believe and a better cam setup that makes more high rpm power. The D2 S8 version makes the most power from factory (same upgrades as S6), but uses a different mount setup, which can be swapped to the A6/S6 version relatively easily. The older ABZ works with a standalone ECU, but the stock ECU cannot be easily reprogrammed like the motronic ECU you get in the 2000-2004 cars. The 2004+ 4.2 engines are timing chain rather than timing belt, and require very expensive engine out service at around 100k miles, those would not be good engines for a swap for the most part.
Member AaronF who posted above has the best info I've seen for the swap, here:
https://sites.google.com/view/boxsterv8swap/home
1thenaton1 is offline   Reply With Quote
