Old 07-28-2020, 01:57 PM   #20
maytag
Who's askin'?
maytag's Avatar
Originally Posted by Finnegan View Post
A buddy in HS bought an old Chevy Malibu and thrashed the hell out of it. When something broke, or started to break, he 'fixed' it with epoxy.
Necessity is the mother of invention.
When I was first married and putting my wife through the most expensive college in the state, I was swinging a hammer for a living. that meant my daily-driver needed to be, well, driven daily, and able to haul my tools back-n-forth to and from projects.
I had a 1982 Datsun B2000 pickup truck for this duty. One day coming home it tossed a rod through the block. I could not afford a motor for the truck, but I couldn't afford for it to not run. So what'd I do? I pulled the motor and laid it on its side in the driveway. I cut two 6"x6" square plates from some 1/4" steel I harvested from a jobsite. I put one plate on each side of the hole in the block and then put a bolt through it, effectively sandwiching the block between them. Then lots of RTV to seal it up. Then I cut the rocker-arms on the cylinder now missing a rod (the piston was good-n-wedged into the cylinder but I added some jb weld to keep it from being able to slip down into the reciprocating assembly). And then I drove it that way.
Craziest part? I drove it that way for almost 6 months! (I lived on a hill that the truck would no longer climb, so I had to enter from above. ) Eventually we scraped-together some cash and I bought an $800 IH Scout ii that was mostly gone from rust, but had a solid powertrain. (Gas was like $0.85/gal at the time....)
