Old 07-28-2020, 07:06 AM   #3
Pattyg
So that code is saying the camshaft is out of time in relation to crankshaft position.
That could happen when things like timing chain tensioners wear out.
Causes excessive play in the timing chain
you could find a scanner that reads camshaft deviation as a check.
If you have excessive cam deviation that would verify the codes.
or verify proper timing by aligning the factory timing marks.
If the above is all ok then I would look to the camshaft position sensor being faulty.
Thanks for your prompt reply.
Pattyg is offline   Reply With Quote
