Old 07-27-2020, 12:35 PM   #14
Qingdao
Qingdao's Avatar
Now, a crush-washer-under-pressure, like on a banjo-bolt or other similar installation, yeah, I'm MUCH more finicky about those. Many years ago, I bought an assortment and stuck it on the shelf. I Literally have a lifetime supply of crush-washers on the shelf, but I still reuse the crush-washer on the oil-pan.... until it gets lost.
Pressure and no pressure (head pressure of less than 15cm is no pressure) 100% different scenarios. I agree.
I ALWAYS use new flat copper or aluminum washers on brake fittings. Oil fittings... sometimes.
I heard an old hillbillie tell me one time you can anneal the copper back into shape and re-use a copper washer. But copper washers like cotter pins are so cheap and plentiful why not just buy a new one. I guess if I was stranded in a desert I could use that information???
'98 PP13B powered "RX986"
