Old 07-27-2020, 12:28 PM   #2
JFP in PA
Originally Posted by Blue99 View Post
The boxster don’t need calibration only the 996 as the tank is a different shape.
Chances are when you put the sender back in you put the wire the wrong side of the float. If it goes across the front of the float it catches.
Sorry, but that is not correct. The Boxster definitely should be recalibrated, "Calibration is required after replacement of the fuel tank, fuel level sensor, or instrument cluster", and the procedure is covered starting on Group 2, page 20-9 in the factory service manual.
