Old 07-22-2020, 10:43 PM   #15
Geof3
Originally Posted by jones904 View Post
Same problem, long work to find C1 blown then good for half day. Now sitting dead as fuse repeatedly blows. Found this forum on hope and applied history: 1-3 bank Vcam solenoid went bad 6 mo ago, cant afford to pull motor and replace with an expensive faulty part so just put up w idling rough. AFTER reading this, aha maybe solenoid has failed worse to a short. Pulled rr wheel and clipped wire. Starts right up no blown fuse! THANK YOU I can go home now. Promise myself only one more failure and shes going to the scrap yard.
I don’t remember which fuse it was, but had a short in wiring of one of my O2 sensors. They are on the same circuit as the fuel rail. Once sorted, all good. 02 3.2
