Old 07-22-2020, 05:45 PM   #21
Homeoboxter
Originally Posted by sfkjeld View Post
Ok, I don’t get this. Just received my new OBDII scanner yesterday. I cleared the 3141 error code (Camshaft Adjustment Bank1 below limit value) that threw the CEL. I cleared the code with the engine running. The moment the CEL cleared, the engine idled down maybe a hundred rpm. In addition, when I start the car after the CEL was cleared, the car does not really “rattle” the 1st second or two after starting as it had. Other than this anomaly, it runs normally otherwise.
Why does the car start and idle differently with the CEL on than off? Why would the chain “rattle” be different? Is that the nature of the 3141 code?
Sounds interesting. What I can think of is that your solenoid got stuck in one position and clearing the code made it go back to where it should be at low rpms. But i`m just guessing. Did the CEL come back? You may wanna ask this question in a separate thread, perhaps more folks will chime in with knowledge about these error codes.
