Old 07-22-2020, 02:40 PM   #2
1PorscheBoxster986
A Porsche Guy
1PorscheBoxster986's Avatar
Does your instrument cluster lights work? If no then check the fuse A5. It is 15A. You can check A8 if your car is from Canada. The license plate lights share the same fuse to the instrument lights and locating lights.
If that isn't the issue then check for continuity in your license plates wiring. You might have a short. This is assuming you have the correct bulb size and the bulb works.
1PorscheBoxster986 is offline   Reply With Quote
