Thread: Loose oil cap
Old 07-22-2020, 01:13 PM   #7
sfkjeld
sfkjeld's Avatar
Yes, the crankcase is under 5 inches of water level vacuum from the AOS while the engine is running. The vacuum is necessary to help the low tension piston rings seat properly.
Sorry, I asked too many questions. Are you saying the oil cap leaking can effect the idle or cooling issues or both?
sfkjeld is offline   Reply With Quote
