					Originally Posted by JFP in PA  Yes, the crankcase is under 5 inches of water level vacuum from the AOS while the engine is running.  The vacuum is necessary to help the low tension piston rings seat properly. |
Sorry, I asked too many questions. Are you saying the oil cap leaking can effect the idle or cooling issues or both?
