Old 07-20-2020, 06:02 AM   #3
blue62
Originally Posted by paulb View Post
2004 S
My start up procedure is different on the Porsche than other cars I’ve had. When you insert the key & turn to the on position it measures the oil & gives a graphic on the dash to show oil levels which takes about 5 seconds. Then you turn the key the rest of the way to start it. Or if you don’t want to wait for the oil measurement, just turn the key all the way & it’ll start immediately. I mention this in case this is an option & maybe everyone doesn’t have that feature
However lately it is not starting regularly. Whether I wait or try to bypass the measurements it randomly just does nothing. When that would happen I just turn key completely off & repeat, usually with a successful start-up. This issue was only once in a while, but now I have to turn the keyMany times each time I want to start the car. When it does engage, all sounds & starts perfectly normal
Is it just that I need a new starter or could the oil checking feature be causing me problems
First things to check:
Make sure your battery cables connections at the battery are clean and tight.
Trace the negative battery cable down to were it is bolted to the body.
Make sure that connection is clean and tight.
There is a small black junction box next to your power steering reservoir in it is a positive cable connection make sure it is clean and tight.
If your issue is not corrected after taking theses steps then you possible have a bad ignition switch. The electrical component not the key tumbler.
From your description of the problem it is unlikely that you need a new starter.
The oil check feature is unrelated to the problem.
