Old 07-19-2020, 09:39 PM   #14
pilot4fn
Originally Posted by tonythetiger View Post
I didn't need it, and I didn't rebuild, I replaced using FEQ (chinese) axles. Never had any problem with them. The caveat with this is they are overpacked with grease, so you need to do a little cleanup 2k or 3K after installation and where they bolt to the transaxle, make sure the bolts are clean of grease, (sometimes they get coated when you push them through the holes) the transaxle bolt holes are clean of grease, you use Loctite on the threads and you torque them (20Nm?) properly. MAKE SURE, cannot stress this enough. You can search the forums for others that give this advice, and those that didn't heed it. Do it right or they will come loose, imagine what happens then, you heard?
Yes, good points. I have seen the posts when you swapped the FEQ drivesgafts. Mine are not in need of replacement /re-lube just yet - just planning ahead and not certain which way to go.
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
