Old 07-19-2020, 01:10 PM   #12
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by pilot4fn View Post
Thanks for these tool infos. Is the offset clamp tools something that can be used also on the driveshaft boots installation if I end up rebuilding the driveshafts?
I didn't need it, and I didn't rebuild, I replaced using FEQ (chinese) axles. Never had any problem with them. The caveat with this is they are overpacked with grease, so you need to do a little cleanup 2k or 3K after installation and where they bolt to the transaxle, make sure the bolts are clean of grease, (sometimes they get coated when you push them through the holes) the transaxle bolt holes are clean of grease, you use Loctite on the threads and you torque them (39Nm?) properly. MAKE SURE, cannot stress this enough. You can search the forums for others that give this advice, and those that didn't heed it. Do it right or they will come loose, imagine what happens then, you heard?
