Old 07-19-2020, 12:07 PM   #11
pilot4fn
Originally Posted by tonythetiger View Post
this is the one you want; beautiful tool, a little more expensive and worth every dime. The HF tool doesn't fit perfect and is cheap all around. considering it will be years, if ever before I do another tie rod, I left this up at my local shop for them to use. They were using the HF tool for the occasional inner tie rod. Rave reviews, enough cannot be said for a tool that is well designed.
you need to google for "OEM Tools 27178 - Master Tie Rod Tool" since the url will get blocked by our hosts.
and the hardest part of the inner tie rods is replacing the little boots. Do a little research and find the offset boot clamp pliers that crimp the clamp, (Lisle model 30600) they are about 15 bucks and you will never use them for anything else, but they work. I gave up the first time I did tie rods and just used stainless zip ties until I got these for the latest task.
Thanks for these tool infos. Is the offset clamp tools something that can be used also on the driveshaft boots installation if I end up rebuilding the driveshafts?
2001 996 C2 Manual
pilot4fn is online now   Reply With Quote
