Thanks for the advice, I went in today and started testing, here's what I got:
In conditions where the car was idling at 0mph, coolant temp at 93 degrees Celcius, the following values were on Relay 8:
85 - 4V
86 - 13.5V
87 - 13.5V
30 - 0V
I shorted 30 to 87, fan did activate (which kinda figured cuz the fan does indeed work just not at the right times). Upon seeing 0 at terminal 30 first, I checked the B4 fuse, but it seemed to be fine. So I'm guessing at this point it's a bad relay. Anyone know what values at terminal 85 and 86 should cause 87 to close with 30? I guess they are cheap enough to replace and see, but given the nature of the compartment fan, I'm going to have a tough time ascertaining whether or not it's fixed outside of going on some spirited driving again.
BTW, it says '53' on top of the relay. Is that all I need to identify it for replacement?
