Old 07-17-2020, 05:23 PM   #23
99Roadster
Thanks for the clarification on which coilover goes where.....I remember watching a video about the distance between holes.
Yeah the instructions say something about leaving the top 2 spinners where they are and after looking at the shock I figured out you spin the shock to adjust.
I measured the ride height before I took it apart and will set it to original ride height.....And the instructions say to torque the spinner to 70 / 80 nm.
When you say suspension are you referring to the rear struts ? If so no I am only doing the fronts at this time.
One more question for you Tony since I will have all 4 stock struts available do you think anybody would want to buy them and what might I charge for a fair price....All 4 stock bilstein struts have no rust anywhere and have 47,000 original miles on them and the only reason I am replacing them is because the right front strut started leaking and I decided to give some coilovers a try instead of going with struts.
99 Roadster base / 5 SP Tiptronic
18" Turbo Twist wheels / Arctic silver W/Black leather Int
Rear wing W/Brake light / 47,000 miles
Side skirts / Bought from original owner
99Roadster is offline   Reply With Quote
