Old 10-22-2006, 01:35 PM   #2
MNBoxster
Originally Posted by drew900uk
Hello again! The other problem i have with my 97 boxster is a rattling sound from the exaust between 1000-2000 rpm. It doesnt seem to be getting any worse but its definately a problem. Any ideas of what it could be would be greatly appreciated. I get scared of being taken for a ride when i take the car to a garage and i just cant afford it right now! Thanks again. Andrew
Hi,
I suspect that you have a heat shield which has loosened up. Porsche doesn't use the best fastening kit on these and so you should try and tighten all the bolts which secure the heat shields. I suspect this will end your issue. Hope this helps...
Happy Motoring!... Jim'99
