Old 07-16-2020, 10:04 AM   #10
specboxCO
I appreciate the offer but I'll need to buy my own when the time comes for the swap. I do have a question about the immobilizer though. Were you able to get rid of it?
The Audi Immo is pretty trivial to bypass. Free software and instructions available on the web - look for me7_95040.exe Nefariousmotorsports.com should have it.
To defeat the immo, use a program called me7_95040.exe to dump the contents of the immobilizer chip to the computer. To do this, I put the ECU in boot mode, by grounding pin 24 of the immobilizer chip for 5 seconds while powering up the ECU. I then ran the program from the command prompt and dumped the file. To defeat the immobilizer 2 bits must be changed at locations 12 and 22 from 01 to 02 and the checksum recalculated. I used a hex editor to change the bit values and then used a program called 95040CSCalc.exe to write the fixed checksum. Using me7_95040.exe I uploaded the revised file to the ecu and the immobilizer was defeated.
specboxCO is offline   Reply With Quote
