Old 07-16-2020, 09:35 AM   #11
aparke4
Installed the Rennline Rear sub frame brace and Tie Downs. Pretty straight forward install but here are some notes/ tips:
My 02 required studs to be punched out... take nut from stud and thread on bottom of studs for a bigger target and tap out with a hammer (studs are splined like wheel studs)
My aftermarket second cat delete pipes were in the way so use a pry bar between exhaust pipe and sway bar to gain clearance needed to remove stud
Apply antiseize on joints going into bar
Apply small amount of blue threadlocker to all bolts and studs... there are not too many times that the subframe braces have to come off but better safe than sorry?
I couldn't quite get logo visible from the back when I tightened up the bar but it didn't really bother me but if you want logo out the back, set up joints and turns accordingly.
aparke4 is offline   Reply With Quote
