Why are people prying off the lens from the dome to switch out the bulb? You simply remove the alien eyes that cover the IR sensors with your fingernail. Unscrew the two torx bolts securing the dome that contains light/convertible top latch/ir sensor. The dome will drop down and from behind you can now access the bulb socket and replace the bulb. It's so easy you don't even have to unplug anything unless you really want to.
