Old 07-14-2020, 03:26 PM   #2
2000_Boxster_S_Owner
Boxster_S_Dude
Step 9 and Step 10
Step 9
Screw in the Shifter assembly to where it was before you removed it. Make sure to remove the bolt and nut or the center console won't fit into place.
Step 10
Place the middle console on over the e-break and back into place. Screw in the screws and connect the power window and seat heaters as well as the ash tray light.
Remember, the white connector are on the driver side of the center console and the black connectors go on the passenger side of the console. Windows are up front and seat heater is toward the back. The light is self explanatory as it is the only plug.
I'll show step 2 again...
Once you have the center console on you will need to snap the stick leather cover in place and put the stick knob back on by pushing the knob straight on to the stick.
The final product should look like this when finished.
Note: The shifter will feel stiff when you shift it outside of the console. Once you put it in the console, it will feel as expected or as before.
2000_Boxster_S_Owner is offline   Reply With Quote
