Old 07-14-2020, 07:23 AM   #2
maytag
Who's askin'?
maytag's Avatar
Originally Posted by robdelorenzo View Post
Bumped for some help, please.
Many people have done a very nice job of painting calipers without actually removing the brake lines from them.
however, if you want to go that route, yes, once you remove the brake line from the caliper, the fluid will slowly dribble out of that brake line. but not under pressure; simple gravity. Sometimes a silicone vacuum cap of the appropriate size can stem the flow while you are painting.
But there is no way around you will have to at very least bleed the system after you reattach them. a full flush is always a good idea when you're there.
