Old 07-12-2020, 12:42 PM   #1
Dawg13154
Angry 2001 Boxter S Hood Release
New Porsche owner and I’m making my first attempt to repair a broken ignition switch.
Could not remove my key after driving it yesterday and realized I would have to disconnect the battery so it wouldn’t drain the power. No problem except I closed the lid before I realized I wouldn’t be able to use the hood release button. I assume the accessory jumper post in the fuse box won’t work because I removed one of the battery cables?
Is my only other option to remove the driver side wheel and try to access the hood latch cable from behind the protective shroud of the wheel well?
To make matters worse, I can’t access the tire jack and bolt socket with the lid being locked. I can use a jack from another of my vehicles; will a standard set of socket wrenches remove the Tire Lug nuts?
I know these are rookie mistakes but any advice would be much appreciated!
Dawg13154 is offline   Reply With Quote
