Old 07-11-2020, 03:25 PM   #14
blue62
Originally Posted by Rodnacious View Post
Success!!! After jacking it up this morning (had to buy new low profile jack and 3 ton stands) and trying different things I pinpointed the problem. I systematically popped off the neutral cable and the downward linkage from the pivot point in the picture. Was able to rule out the cable and the internal transmission spring from being the problem. The bracket in picture pivots on a single bushing to move the neutral cable. That pivot point was very stiff and was corroded inside when I took it apart. Some steel wool, 1000 grit, and CLP got the job done. Put it back together and it moves 75% better and returns to neutral from 1/2 but not from 5/R. I’ll try adjusting the cable threads to get it centered. So if you are having similar problems take that bracket off and clean the bushing. Was easy to remove and clean, plus save a lot of money!
Looks like some grease wouldn't hurt it
Looks like your getting the issue resolved.
