Old 07-10-2020, 01:50 PM   #10
truegearhead
truegearhead's Avatar
Originally Posted by specboxCO View Post
Are you trying to use the Porsche ECU with the Audi engine? When I did my 4.2 build the ignition wiring was pretty straight forward, but I used the Audi ECU. If you keep the Audi ECU & engine together, there is no additional wiring needed for injectors.
I’m using both ECUs. The Audi ecu to run the engine and fuel pump and the Boxster unit for the chassis. That’s the plan at least...
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
