Old 07-07-2020, 07:13 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
On the 1997, I see one connection directly between the DME and ABS 5.3, a wht/brn wire "Speed RL" (rear left?) it also connects to the instrument cluster.
DME, Pin 79----- X3/1, Pin 21 ----- ABS, Pin 23
|---Cluster, II 16
My guess is that it is a signal that goes FROM the ABS unit TO the DME. I guess that because the ABS unit has input from 4 wheel speed sensors. The (1997) DME does not get any speed input directly from the wheels, it would have to be through the ABS.
