Old 07-07-2020, 02:50 PM   #10
blue62
Originally Posted by Rodnacious View Post
More info, when in neutral if I move the shifter left and right it just sticks there and does not return to center. Should these shifters return to center or stick as described?
It should return to center.
I don't know of any standard transmission that doesn't.
Now that you have everything exposed disconnect the cable that seems to be causing the issue and see how the shifter acts.
If it feels good then you know something with the disconnected cable is the issue.
Perhaps at the transmission end.
If the shifter is still stiff you know the shifter is the issue.
If I remember correctly the cables are simple to disconnect.
