Old 07-07-2020, 07:16 AM   #15
Jasper7821
I'll put my 5'/100lb wife in charge of the ignition switch. My hands are like mittens when it comes to those tight spots.
Good luck on the windows and... Tony's advice sounds good: "...once you go to the trouble of accessing the regulator, best to just change it out.". I know I'll consider that if ever I have to check out regulators.
Good luck!
Ya, I had to go to the chiropractor after changing the brake light switch.
We'll see about the regulator, from watching some videos it doesn't seem all that bad. And several people have said it's been a long time since they did the cable tie or adjuster and the window still works just fine. So we'll see.
Jasper7821 is offline   Reply With Quote
