Old 07-07-2020, 05:16 AM   #14
Starter986
1998 Boxster Silver/Red
Originally Posted by Jasper7821 View Post
First thing I did was change the brake light switch cause the car had no brake lights. That was easy except for how limber your body has to be to get to the switch.
Next I’m going to tackle the “window won’t drop” trick with cable ties or bicycle adjuster. If that goes well, maybe then I’ll try the track arm link.
I'll put my 5'/100lb wife in charge of the ignition switch. My hands are like mittens when it comes to those tight spots.
Good luck on the windows and... Tony's advice sounds good: "...once you go to the trouble of accessing the regulator, best to just change it out.". I know I'll consider that if ever I have to check out regulators.
Good luck!
1998 Porsche Boxster
