Old 07-06-2020, 01:56 PM   #14
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by Jasper7821 View Post
First thing I did was change the brake light switch cause the car had no brake lights. That was easy except for how limber your body has to be to get to the switch.
Next I’m going to tackle the “window won’t drop” trick with cable ties or bicycle adjuster. If that goes well, maybe then I’ll try the track arm link.
sincere advice on this is once you go to the trouble of accessing the regulator, best to just change it out. The ball bearing regulators work better also. Remember to make sure you don't disconnect the airbags before disconnecting the battery or reconnect the battery without having the airbags connected. :+)
