Old 07-06-2020, 10:17 AM   #11
Homeoboxter
Originally Posted by DaveBBOXSTER View Post
Yes, I agree with those points. I do some DIY but probably not capable of replacing variocam actuator, as it involves timing, etc. If I knew the one that was failing and the exact part number I'd get a good used one and get it put in...Done a few trips totalling 70 miles now and engine exactly as it was. Got recovery cover for a year as back up too. Plan to check filter again after a few hundred miles and see what it has in it.
An easy thing you could do is to remove one of the green plugs on the camsafts on either side and take a peek into the gap. You can see the actuator from an angle and one of the pads. If you ask somebody to rotate the crankshaft with a wrench (clockwise) you can inspect the actuator if there`s any movement. There should not be anything, and probably there isn`t, because it would rattle otherwise, but at least you would get an idea if things look ok. At least things that you can see there. I`m not sure actually what you can see with the engine in the car, my engine is on a stand now. If you have a boroscope that may help.
