					Originally Posted by  tonythetiger
				if you shop around, they are usually around 125 each. I've just replaced everything once I'm in there, but I'm sure I spent money I didn't have to. The fork is the normal culprit for low-speed clunk and you can't tell until you replace it.
Look at the drop links and sway bar bushings as well, you can probably tell if those have issues from inspection. Dont forget, at that mileage, (100K?) your struts are likely worn also.
Thank you very much. Will dive into it maybe next month.
