Old 07-02-2020, 01:21 PM   #1
Jasper7821
Originally Posted by tonythetiger View Post
if you shop around, they are usually around 125 each. I've just replaced everything once I'm in there, but I'm sure I spent money I didn't have to. The fork is the normal culprit for low-speed clunk and you can't tell until you replace it.
Look at the drop links and sway bar bushings as well, you can probably tell if those have issues from inspection. Dont forget, at that mileage, (100K?) your struts are likely worn also.
Thank you very much. Will dive into it maybe next month.
Jasper7821 is offline   Reply With Quote
